RevvdMedia
I saw a couple threads on this but haven't seen an answer, has anyone figured out how to "pull down" the glovebox to get to the cabin air filter? I don't need to change mine yet but I need to run some wires in that area for an EQ I'm installing (You'll see later)...
I did find out how to do it, but I don't know if it is the right way. You push the sides in around the rubber "cylinders" (stoppers) which gets it most of the way, but there is a little arm on the right side that it is stuck on. I gave it a tug and it came down, but this dislodged the little plastic geared wheel that is what controls the speed the glovebox falls. While this did get it open, and the wheel went back in just fine, I can't see this being the right way. I thought I broke it! :eyebulge:
Anyone done this yet?
