CJ Pony Parts
- Dec 21, 2015
- Harrisburg, PA
- Website
- www.cjponyparts.com
- A large variety of Mustangs across all generations
[ame="[MEDIA=youtube]zNTxWoNBzv8[/MEDIA]"]
IN STOCK and available in your choice of a Clear or Smoked Lens as well as the optional DRL Harness.
If you're looking to improve the exterior of your 2015-2017 North American-Spec Ford Mustang, than start with something easy, like exterior lights! Order this upgraded Pair of Diode Dynamics Clear or Smoked Sequential LED Turn Signal Assemblies (DD5001 and DD5011) today from CJ Pony Parts!
Sequential LED Turn Signal Assembly Features:
- Pair of two (2) turn signal assemblies with clear or smoked lenses for the driver and passenger sides
- Direct-fit upgraded sequential LED turn signals have programmable speed
- Complete plug-and-play installation with OEM connectors
- DOT/SAE compliant pattern is brighter than stock
- Optically designed for OE-grade performance
- Optional DRL Mode (requires separate wiring harness) provides high output visitbility
- Proudly made in the U.S.A.
- Will fit all 2015, 2016 and 2017 North American-Spec Mustangs (Including the GT350 and GT350R)
[MENTION=9987]Diode Dynamics[/MENTION] understands that the exterior of your new Mustang should be as sleek and modern as possible, so it makes total sense to upgrade from those boring incandescent turn signals to something superior, like these sequential LED assemblies! You'll receive a pair of two (2) assemblies for the driver and passenger side of your pony. Each assembly features a crystal clear or smoked lens and a premium-quality set of LEDs--one clear to give off a bright white light and one amber for the turn signal function. These front marker lights can function like daytime running lights when your indicator is not in use (with HW4041), but will instantly flash amber whenever you go to turn or change lanes. You can program the turn signal speed, or get even more functionality out of the lights with a specialized DRL wiring harness (sold separately) to help increase overall visibility. These high-quality lights will quickly and easily install since they come with factory-style connectors already assembled, so what are you waiting for? Hurry up and grab these modern LED indicator assemblies today from CJ's!
Tech Tip: To get the absolute most out of this pair of turn signals, be sure to grab these DRL wiring harnesses (HW4041) to activate the daytime running light function.
Please Note: Will NOT fit models that are manufactured for distribution outside of North America due to differences in the factory wiring.
Pick up this upgraded Pair of Diode Dynamics (DD5001) Clear or (DD5011) Smoked Sequential LED Turn Signal Assemblies along with the optional DRL Harness for your 2015, 2016 or 2017 North American-Spec Mustang from CJ Pony Parts today!
