Enzo
Hey guys so here's the story. I have a new 2016 gt pp manual. I only have 5k miles on it rite now before I started doing any mods to it I drove it around for a couple of thousand miles and ended up finding out that driveshaft needed to be indexed. I go that done. Everything fine. I waiting about 500 miles or so and started to modify the suspension, I lowered the car and on springs and swaybars only and a couple hundred miles later when I go into a driveway it does a clunking sound or if I take wide turns it does the clunking sound. I only notice it when driving at slower speeds and during a turn or going into driveway. It will not do it on speed bumps or regular bumps. Everything sounds perfect when driving straight and turning at speed in gear but when turning slow it makes the noise. Now here's the weird thing it does it when in neutral. If I put the car in gear going into the driveway it won't do it unless you drive quick and rough but the it only does it a little. I replaced the end links thinking it was those since I lowered it and put stiffer swaybars, but nothing changed. Please I need some help guys it's driving me nuts!!!
