TorqueMan
- Aug 24, 2017
- St. Jacob, IL
- 2017 EcoBoost Premium
Everyone has their favorite. The discussion about standards IS pretty pedantic, but the point is a standard defines expected performance. Pretty much ANY name brand semi- or full-synthetic 5w-30 oil you use will meet warranty requirements and provide satisfactory wear protection. It's been shown time and again there is no difference in wear protection among oils from different manufacturers—assuming you are comparing like oils. Other considerations such as piston deposit formation, oxidation stability (to allow longer oil change intervals), volatility (to limit intake valve deposits), etc. are a concern with our engines because of their design. Different oil standards have been developed by different agencies to address these (and other) issues.Really interesting stuff. For the filter, I think I am just going to go with the Motorcraft FL400S which seems to be a little bit bigger. I plan on making my oil changes every 7-9k miles so like someone mentioned above, there is little to worry about in terms of contamination in the oil for the filter to be challenged.
For oil, I am still not sure at all... I see all these certifications thrown around but not sure which one fits this engine better? Like I said, my car only has stock motor, a levels intercooler that will be installed soon, and she is my DD with some casual spirited driving.
GF-5 is the latest International Lubricants Standardization and Approval Committee (ILSAC) standard, and is the standard recommended by Ford in your owner's manual. (Note it is RECOMMENDED, not required. The only warranty requirement for the oil you use is that it meet the latest certification for the American Petroleum Institute [API]). GF-5 was introduced in 2010, and meant to address oil-related issues specific to engines like the ones in our cars. Click here to read more about ILSAC oil specifications.
The dexos 1 Gen 2 (D1G2) standard was released in 2015, and as the name implies, is the second generation of the dexos1 standard. As Brian V. has pointed out, this is a General Motors standard, and an oil manufacturer who wishes to put a D1G2 compliance statement on their label must pay a licensing fee to GM. Brian has suggested that a licensing fee is all that's necessary, but that's not factual. There is a test protocol oil manufacturers must follow to demonstrate compliance with the standard.
The D1G2 standard addresses all the same issues as ILSAC's GF-5 standard (and exceeds the GF-5 standard for most of them), but adds protection against low-speed pre-ignition (LSPI), which is a relatively new problem related to engines like ours. LSPI is a rare event, but under the right conditions it's been shown to cause catastrophic engine damage, so the consequences are dire. Research continues into pinpointing the primary cause(s) of LSPI, but a lot of testing suggests oil formulation plays a role. GM's test protocol seeks to demonstrate that an oil is LSPI-resistant under the conditions where it is known to occur. Click here to read more about the D1G2 standard.
So, the long and the short of it is you may use any semi- or full-synthetic 5w-30 oil that is API certified to meet your new car warranty requirements. If, however, you want an oil that meets the latest performance standards for mitigating the kinds of oil-related issues common to small-displacement, high-output, direct-injected, turbocharged engines like the one in your car, you should use an oil that meets the D1G2 standard.
