Whipple Gates Belt Squeak
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
For the most part it will show up as aligned, but there are 5 support stands on the back of the spring loaded/idler plate. These if pressed in just slightly crooked can crush the aluminum in the radius, and not let it seat all the way. This then makes the tensioner track at just a slight angle, loading the idlers at an angle, causing bearing and belt chirp.
The Gates/Dayco alignment tools are excellent tools but this should show up with the plate off and a straight edge.
Any reason why these support stands could not be pressed and pre assembled by Whipple. Seems it would avoid these complaints and slight miss alignments.
Whipple SC
Fresno
We opened up the tolerance so its not a press fit. The press was only for installation ease. Now they just sit in there so its not possible to press at any angle.
DiEzel
GTFO OG - The Professor
San Diego
Ray
Oxford white GT Premium PP
Can confirm. Installed mine, They no longer need a press fit. Belt doesn't sqweek here!
At first I thought my plater took a little to much off, But - clearly it was a design feature.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Excellent to know and thanks for the efforts enhancing your products when needed.:thumbsup:
Super Werty
AZ
2015 PP GT
So just to confirm there is now a non press version?
[MENTION=13288]Whipple SC[/MENTION] would you guys be willing to send me the new version and a new belt? Mine is chirping at all times now and it doesn't sound good.
On a straight edge or flat surface mine appears to be good but the chirping says otherwise
Dat Boi Kumar
Rosharon,Tx
Chad
2015 Comp Orange Mustang GT
Please check alignment of the support stands first, more than likely it is off and therefore the belt will only temporarily fix it. If alignment is corrected, the same belt will be fine.
[MENTION=13288]Whipple SC[/MENTION] I tested it out and both set legs are a little off. Can you send me the new legs
Dat Boi Kumar
Rosharon,Tx
Chad
I'll give a update on my belt squeal. I recieved the new bracket legs from whipple and put it all back together with the same belt. The squeak was still there. I went and bought a new belt and as of now there is no squeak! I guess the old belt got worn out from the bracket being off. Thanks [MENTION=13288]Whipple SC[/MENTION] for the great Customer Service.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2022 F150 PowerBoost
Thanks for the update. I got mine today (thanks Mike!) but didn't get the chance to install yet. I have a feeling I'll need a new belt for the same reason but unfortunately mine is a 10 rib so I can't buy it locally. I'll update when I can get a chance to install them.
SmokedSS
Baton Rouge
2015 GT Premium
Looks like after 1500 miles I now Gates belt squeak :( Plan to check pulley alignment and then maybe rotate the belt?
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
This is frustrating to hear this, a noisy drive system is not something I can stand. I hope this is an isolated issue, but sounds like more than a hand full have problems. I hope Whipple can resolve these issues with you guys having this problem.
sonic
NY
Prius
I'll pay extra attention when I install mine
BLKONBLK2015
Lake Mary Florida
2015 Mustang GT PP
Turn the belt around. Solved it for me until I pulled the Whipple off a few days ago.
Jmeo
You said member ;)
Massachusetts
Jaime
Did your squeal ever come back? I assume you pulled the SC off to do new idler bracket feet and maybe new injectors?
BLKONBLK2015
Lake Mary Florida
2015 Mustang GT PP
Belt squeal never came back after turning the belt around. I am selling my car so I took the Whipple off. Figured selling the Whipple would be easier than selling the car with the Whipple on.....
Jmeo
You said member ;)
Massachusetts
Jaime
Awe, I'm sorry to hear that. May I ask why?
