mustangcobra93
I didn't realize you had four options on the MGW shifter. I'm thinking about the standard x-spec. What did you all go with?
The installation of a shifter won't void it, but any damage it could cause will.Thanks for the info! By any chance anyone have someone they trust in KY that could install one? Also, a shifter doesn't somehow void the powertrain warranty does it?
The shifter is a great upgrade, hands down. You're going to shift harder/faster into gear which if you miss or slam it, the end result will be bad. That could happen with a factory shifter too, but if they find out you installed a shifter and you're trying to warranty a broken transmission, they will blame it on the aftermarket shifter. I think you'll be fine, but its a possibility.How would a shifter cause damage to the transmission, assuming it's installed properly? From all the posts I've read about this transmission a new shifter is a popular mod to help with annoying issues.
where at in ky do you live?Thanks for the info! By any chance anyone have someone they trust in KY that could install one? Also, a shifter doesn't somehow void the powertrain warranty does it?
