HextallS550
- Jan 2, 2017
- Dearborn, MI
- 2017 GT
@stang1971 check your trunk to see if you have the connector that @Robertp has shown
Do you think this would cover it?I will need to check. The lengths on the bottom mounts are no big deal. Theres plenty of room for extra threads. The top bolt that goes into the body clip needs to be a certain length. Let me get back to you.
Where did you obtain the Shaker plaque? Did you have to pull apart the dash and console to install it?I bought all the oem stuff it was not very much at all plus this way mine looks factory even bought the shaker plaque below the radio
That's good to hear. It's just a little something that would be nice to have to 'finish' this off and make it as 'factory' as possible. Now I just have to find the actual plaque...I think all you need for the plaque is to pull the tray out and you can get under it and pop it out. I forget if the center console trim needs to be pulled back but that's not hard.
I saw that you asked about the SP and the B&O speakers in some other threads, I'm monitoring those as well.Are you doing all the speakers too?
I asked a question in another thread if the SP speakers are a direct replacement for the Premium setup but haven't gotten any responses.
It's impressive that they shipped it out overnight. When I saw the prices on Ebay for the subwoofers I nearly went the same route as you. However, I was lucky enough to find a salvage yard that had a sub in good condition. I was able to get the subwoofer enclosure with attached amp, mounting bracket, cover plate, trunk carpet and some mounting hardware shipped to me for $200. I had to scour car-part.com for ages, but it paid off in the end.I ordered the Sub from parts.ford. It shipped to the dealer overnight! For what people are charging for horribly beaten up subs on ebay it made sense to get it new.
Nice! that is a tough find. People seem to forget about the mounting hardware when they put them up for sale. I've seen a few listings with the harness wires just sliced right off too. Which probably required more effort to cut than it would have to unhook.It's impressive that they shipped it out overnight. When I saw the prices on Ebay for the subwoofers I nearly went the same route as you. However, I was lucky enough to find a salvage yard that had a sub in good condition. I was able to get the subwoofer enclosure with attached amp, mounting bracket, cover plate, trunk carpet and some mounting hardware shipped to me for $200. I had to scour car-part.com for ages, but it paid off in the end.
Did you end up going with the M8-1.25mm x 30mm bolts from the Ebay listing to mount the sub?I've got my Shaker Pro sub up and running. It made a much bigger difference than I expected!!! The Shaker Pro system may not be that great but it's better than Premium.
