bdub85
That's what they are there for. I scrape mine all the time.Scraped my front lip, though it was just the rivets - again :headbonk:
I sure hope you are doing a DIY with lots of pics and comments as you go along .retrofitted a factory differential cooler to my tech pack. Took me a little bit to figure out the evap shield/radiator fitment, but all in all, it's pretty damn easy. If the evap shield is the same on a regular GT, it should fit without issue on 5.0s as well (with a diff cover swap.)
All I have left to do is Finalize the wiring on it. I made a Alpha harness to verify pinout and function. Everything fired up fine. I'm probably not going to do a thermal switch this go-around, but i'm using weatherpack ends and making it modular so it won't be too difficult to add a thermal switch and/or sending unit for temp controlled on/off and monitoring. This way, once ford releases their stuff, if there is a computer flash, I can also take my wiring out easily, add theirs, then do the flash.
Tomorrow is trans cooler day.
Readings are making sense. After running the car in 5th for 10 minutes at 80 mph (rpm about 4K or slightly below) the tranny temp steadied at 185. Took a screenshot after I exited the parkway; tranny at bottom left, coolant at top right.Big thanks to KevDog. :hail:
Looks like I have my tranny temp. working on my IPhone Fusion OBD app. and using a Kiwi3 to read and transmit.
Heading out to an autocross tomorrow and will confirm if all the readings make sense.
I will not be documenting anything transmission related for the time being. No clue how this will all play out.I sure hope you are doing a DIY with lots of pics and comments as you go along .
Once I seen the pic I knew what you were getting at. Jesus Christ! Some asshole tightened the plug to tight. Fill and drain plugs are tapered. You gotta be kidding me. Guess what now! You'll be getting the R / track pack / 2017 trans! This will help your trans cooler install since it has a pump in it! I guess you could call it a blessing in disguise. I hope to God the dealer doesn't give you shit for the mods you already done. I'd be pissed if they did. Good luck. I would also contact ford performance.I will not be documenting anything transmission related for the time being. No clue how this will all play out.
UI started today with installing the factory radiator portion of the trans cooler setup. After I installed the finned radiator part, I put everything back together and went for the recommended 20 min drive to get the trans fluid warmed up ( as noted in the fluid change procedure doc from optimum. )
A bit of background because it matters... I generally park my car inside my yard, under my car port when I'm using it on a semi-regular basis. ) I rotate other cars in my collection and my garage is about 20 mins from my house.)
The driveway in this area is a split concrete setup with grass in the middle. I thought that the grass was dying because of the infestation of a specific type of larvae/moth that New orleans has been dealing with. When i park my car, the drain plugs are obviously over this grass strip. Turns out.. it isnt the moths killing the grass.. it's my car!
This is probably the first time that I have driven my car, then brought it home and parked it right on top of concrete in a couple months.
So today, being that I'm on a mission, I pull the car inside my house's garage.
I put the car up on my race ramp wheel cradles, then go inside to let it cool for a bit. About 30 mins later, I come back out and find that the car has decided to mark it's territory. You guessed it. transmission fluid. I'm completed perplexed, as i haven't touched the trans yet.
I start looking around to try to find the leak. Keep in mind, I have NOT touched the transmission at all yet. All I have done is install the finned part and brackets. I'm not able to locate the source of the leak at first glance
So! before I go any further, I take my pictures because I know there is something wrong. Cars with 2600 miles on them are not supossed to leak transmission fluid. Here is what it looked like after i wiped it with a rag to take the pic.
After I snap the pic, I decide to gently remove the plug to see how much fluid is left in the trans. I drain it into a fresh, clean pan. I measure. 1.6 quarts. Now, My impression is that the car takes 2.6-2.7 quarts. I still can't figure out why it is leaking, or where it is coming from.
Oddly, My trans has been reading in the upper range of those that have been reporting their transmission temps. It's almost always over 200 degrees after the car warms up. Now I know why.
So, I go back inside to look at the pictures on my computer in hopes that blowing them up will make it more obvious. and.....
The transmission split right at the casting/weld! Go back and look at the pic i posted, you can see the split right down the seam.
I'm calling my dealer in the morning to have the car towed to them. Pretty blown away by this. I'd never had a vehicle that split a transmission like this.
if headers, exhaust, rear suspension and interior mods caused a transmission case to split, I'm morgus the magnificent.Once I seen the pic I knew what you were getting at. Jesus Christ! Some asshole tightened the plug to tight. Fill and drain plugs are tapered. You gotta be kidding me. Guess what now! You'll be getting the R / track pack / 2017 trans! This will help your trans cooler install since it has a pump in it! I guess you could call it a blessing in disguise. I hope to God the dealer doesn't give you shit for the mods you already done. I'd be pissed if they did. Good luck. I would also contact ford performance.
Yep ... I saw the crack right away in the boss the drain plug screws into. :doh:Once I seen the pic I knew what you were getting at. Jesus Christ! Some asshole tightened the plug to tight.
whats crazy is that the crack goes all the way up tot he point in the casting where they grid/trim.Yep ... I saw the crack right away in the boss the drain plug screws into. :doh:
This photo you took doesn't look like any welding was done to me - I zoomed in on it some more. It's just a nice clean crack all the way up the side of the drain plug boss all the way to the main case. I think that flashing you see to the right of the crack is just normal casting flashing that they probably ground off ... not a weld IMO.whats crazy is that the crack goes all the way up tot he point in the casting where they grid/trim.
Furthermore, it is impossible to see in the pics because i took them with a shitty camera phone, put it looks like it was welded then ground down where the crack happened.
I would love to be optimistic in that thinking but I got my new transmission 2-3 weeks ago and they wouldn't give me the better one.Guess what now! You'll be getting the R / track pack / 2017 trans!
