***Urgent*** Check Clutch Line At Brake Master Cylinder
EF300
The Swamp, Central FL
2017 GT350, 2020 GT500 CFTP
Yes I just had my fix under warranty at 13000 miles. Just make sure it's leaking when you take it to the dealership because they have to actually see the problem in order to get a warranty repair if you know what I mean.
EF300
so those knuckleheads at ford "fixed" mine but its the same damn tube. Its gonna fail again. Aftermarket mod needed on this one !
GT Pony
Pacific NW
I thought someone in this thread said there was a new part number for that hose? Maybe it was some other part. :shrug:
Traavis
Travis
2015 GT
Mine was the same. it seems to me that the line is a little too short, which is causing it to pull back. I could push mine up, but it would slide back some. I pulled back on it a little and it would always stop at the catch.
Seems like Ford could make a longer line and it would fix this issue. talking 1/2" at most.
tj@steeda
Timothy
Great news, our team is currently investigating a fix for this - I will let you all know when our R & D is complete & if we can create a cost-effective solution.
TJ
HaximusPrime
Dayton, Ohio
2017 Ruby Red GT-PP
TJ
Might be a good idea to collect names of people to PM when this is ready. I'd be interested, but don't pay enough attention to the forums to notice a post when done :-/
Or maybe start a thread specific to this project that we can subscribe to?
Lightning
Miss my 93
Montreal Canada
50th anaversery GT, 2019 Golf R
TJ
That’s great news and yes maybe start a thread specific :headbang:
Optimum Performance
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
TJ
Build a remote clutch reservoir solution as a longer line version.
tj@steeda
Timothy
Once I know more, we'll start a new thread & see if we can get 6G to feature it.
But like I said, we want to ensure we can meet expectations.
Best Regards,
TJ
GJarrett
Tampa FL
2017 EcoBoost Premium
Just noticed this thread and checked mine.... wowzers it was out at least as far as your first photo if not farther :shocked:
Thanks for the heads-up!
BrandonB
Tinted Window Licker
Central VA
'18 GT Oxford 301A
Best Regards,
TJ
I hope you guys come up with a solution sooner than later :(.
I can confirm this is STILL an issue for 2018. Mine was loose and leaking with less than 400 miles on the car. 12/17 Build 2018 GT. I performed the "Zip Tie maneuver" mentioned earlier in this thread.
GT Pony
Pacific NW
That's nuts ... doesn't Ford even hear about on-going issues like this? Are they all asleep at their desks?? Come on Ford ... wake up!! :doh:
SMJ540
GA
2019 GT
Follow up.
After my discovery of the leak when under vacuum I decided I had enough of this hose. So I ordered the Tilton Brake and Clutch Fluid Hose 74-214 and decided to replace the entire hose all together. Also added two clamps. The clamps not absolutely necessary. The barbs on both the reservoir and clutch master cylinder gripped the hose very well.
I wanted to eliminate any chance of air getting in the system.
This is a nice idea, I found mine was loose and was slightly seeping. I don't trust the dealership to actually fix this properly and judging by other posts, they'll just put the same crappy line back on it.
Can you describe what you did when removing the line? It's my first time removing something like this.
Did you drain the brake reservoir first, and then remove the line with just something underneath to catch fluid? Or does it not drain without some kind of suction?
Did you have to bleed the clutch after wards?
Thanks!
