Tuning Question! MPG doesn’t match full tank mileage!
JustinReed
Santee
2017 Mustang GT
I fill up my car, at the time I was averaging 14.5 mpg, but when my tank was full, my (miles to empty) read 187 miles, when it should be around 217 miles. I’m running 91 right now, not e85.
I’m also getting what looks like a carbon build up on my rear valance.
My car is dyno tuned, am I correct thinking that my car is tuned to rich, and that could be the issue of why my actual mileage isn’t matching what my gauge is reading?
Any help is appreciated, this is rather frustrating...
Zelek
Round Rock / Hutto, TX
2021 Mustang Mach 1
There's also a pretty distinct smell at idle for a bit when your car is running rich. The fact you already can see buildup on the rear is a bad sign. I would probably have your tune checked and do some data logging.
It will also help if you can monitor some of your stats while you drive like your AFR.
white15gt
Michigan
White 2015 GT
The DTE on the dash is a 500 mile rolling average. It doesn't change based on the MPG on the dash
EFI
Masshole central
5.Br0
1) take miles to empty with a grain of salt
2) you can easily tell if your car is running rich or not just by looking at the gauge cluster and seeing what the AFR is. Should be high 13s low 14s cruising.
3) have you actually calculated the MPG/miles per tank or are you just frustrated at the poor estimation in the dash
JustinReed
JustinReed
Santee
2017 Mustang GT
The only calculation I’ve done is the math of my mpg and miles to empty. Before, when I would average 15-16 mpg, my miles to empty would be much higher.
