Tuning Problem - 2016 Mustang GT Lund
nolab
Springfield IL
Nolan
2016 mustang gt premium
2024-05-13 15:22:56
2016 Ford Mustang GT Coupe, 5.0 L, V8
Readiness Monitors
Confirmed Emissions Fault Codes: 3
MIL is On: Yes
MisfireComplete
Fuel SystemIncomplete
ComponentsComplete
CatalystIncomplete
Heated CatalystNot Supported
Evaporative SystemIncomplete
Secondary Air SystemNot Supported
Gasoline Particulate FilterNot Supported
Oxygen SensorIncomplete
Oxygen Sensor HeaterIncomplete
EGR and/or VVT SystemComplete
Warmups Since Code Clear: 0
Distance Since Code Clear: 0 Km / 0 Miles
3 Fault Codes Detected
0x7E8 Engine Control Module
P163FSES, Pending, Current, Permanent
Transmission ID Block Corrupted, Not Programmed
P2251SES, Pending, Current
O2 Sensor Negative Current Control Circuit/Open - Bank 1, Sensor 1
P2254SES, Pending, Current
O2 Sensor Negative Current Control Circuit/Open - Bank 2, Sensor 1
Current mods : 47lb injectors, SP headers, CAI, 2018+ intake manifold.
I don’t have any defoulers or anything on, which I’m thinking could be the problem. But on my laptop it does say I get a OL - Fault code for the fuel section and I don’t get any readings there/O2 section. Any help would be amazing, thank you!
joe603
ATL
Joe
2021 GT Premium PP
No idea...but I've heard Wengerd is the bomb.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Looks like you have a broken wire or corroded connections in the O2 plugs.
Thats where I'd start looking anyway.
GL
ORRadtech
Atlanta, Georgia
Defoulers only affects downstream sensors (bank 1 & 2, sensor 2). They have nothing to do with the upstream sensors. The upstream sensors are what affect the fuel trims, the downstream sensors are simply to measure how efficient the cats are. The codes you have for the O2s seem to indicate an electrical connector or wiring issue.
I don't have a clue on the transmission code.
