Madlock
I'm hoping someone already may have solved this dilemma.
Many who don't drive their cars daily and especially those who store them for the winter often do so with a trickle charger attached to keep the battery topped up and the car always usable rather than allowing the battery to go flat over time.
Most popular battery maintainers include offer as accessories a quick connect pigtail one may content directly to the battery terminals which are much more clean and convenient than clamps and so forth. Even the hood needn't be open while being maintained over long periods.
In the process of affixing quick connect pigtails to my stored S550s, I noticed how the ground lead's eyelet conveniently slips atop the battery's original grounding cable beneath the 10mm nut. But no such equivalent exits at the positive terminal, except the 10mm nut atop the compression fitting which just doesn't seem nearly as ideal.
I'd be grateful to know what others have done. Do you use the compression fitting bolt as a connection point for the positive quick connect lead or do you do something else which involves a different pigtail or adapter?
Thanks in advance for any relevant guidance.
