- Aug 14, 2015
- Mountain View, CA
- God bless America, all 8.4 liters -Randy Pobst
- Banned
- #31
Good intel, im not Terry Fair, dumbass.Terry Fair? dude?! I met you once at an SCCA event but really?
"Buy at your own risk? email Vorshlag?"
Thats awesome! talk smack about another vendor that has a proven record supporting grass roots motorsport and then say call you instead. :dnftt:
Uh wait.. Terry, from your own thread you ran spacers:
-We've found that there's really not one backspacing that fits properly front and rear (the GRAND AM teams use 18x10's with slightly different offsets front and rear)
-The 18x10.5" ET38 fits on the front with camber, but not the rear
-The 18x10 ET38 Enkei RPF-1 fit the rear "fairly well" but needed 7mm of spacer to clear the brakes
So you were learning that you can run a wider wheel in a square setup on a stang by using spacers on the front and same wheels tires all corners. Square setup means same offset same wheel same tire so you can rotate front to rear to save money on HPDE/track time without having to mount remount tires.
Sucks if you are stuck with $30,000 in wheels trying to support mustang crowd:
http://www.sccaforums.com/forums/aft/47484/afpg/4
Respect to you for trying.
But since you got rid of that pallet you aren't in a bind trying to sell them.
Since then you switched to selling Forgestar 18" CF5:
http://www.vorshlag.com/index.php?cPath=141_322_330
http://www.vorshlag.com/product_info.php?cPath=141_322_330&products_id=749
Now in the mean time Apex works directly with a manufacturer to get wheels built for track use crowds in BMW and now S550.
Real "Track use" means substantial risk in wheel failure to yourself and other drivers at speeds above 100. This does not mean picking the lightest weight wheel you can find and risking your life and others with it. I heard COTA banned ROTAs after it cost them $12,000 to have Wheeler resurface a corner. lol..
For SCCA parking lot cone dodging, the lightest flimsiest<-is that a word? wheel is probably fine. You are not likely to spin half on/ half off the racing surface at 100. To be fair, Watch out for lightest weight being used as a leading marketing/selling point.
Apex wheels are the real deal at $330 comparable to $350 Enkei's and CF5s.
edit: Apex wheels are the real deal at $264 <=!
http://www.apexraceparts.com/apex-products/S550-Mustang/18x10-ET43-APEX-EC-7-Mustang-Wheel.html
Maybe lay some 4x4 timbers across the road and run some various wheels across them and see what speeds they all survive up to. Got a ranch truck to loan out for the test.
Vorshlag running COTA this February? Get you some Apex EC7s available today and come on out!
mod in 3,2,1...
Also, I posted this as a reference. If you scrolled through that thread you will see what works and what doesnt, the main purpose was to show the weights (notice they didnt even mention Apex!) lol. I will gladly spend $30 bucks more per wheel to save weight. That apex wheel is heavy as shit, good luck with heavy ass wheels vs proven enkeis.
This part is golden:
Watch out for cheap wheels too, Enkei is proven and makes wheels for all sorts of brands. Apex? Never heard of it till I saw it in these forums.For SCCA parking lot cone dodging, the lightest flimsiest<-is that a word? wheel is probably fine. You are not likely to spin half on/ half off the racing surface at 100. To be fair, Watch out for lightest weight being used as a leading marketing/selling point.
Edit:
I just got home and looked up what my Forgestar CF10 weighed when I put it on the scale (10.5" wide, 20" rim), its 24lbs. The op's Apex wheels are 10" wide, 18" rim @ 22lbs.
