Rodpwnz
- Oct 14, 2019
- SF Bay Area
- Rod
- 2018 A10 PP1 401A GT
Yeah, I'm well aware of the cooling solutions, as I've been following those guys on this forum and another more track oriented forum for some time now. The best cooling isnt just throwing larger coolers, but also better airflow in AND out.My 2019 GT was a premium non-PP car. The A10 clearly behaves very differently in my Mach than it did in the 2019. I also cannot confirm if the car actually received a redesigned torque converter or if it is merely tuned differently.
-I was referring to the 180⁰ engine thermostat. In my 2019, even with a mishimoto triple pass radiator, coolant Temps could reach 220⁰ under normal driving on a hot day. The mach tends to to sit around 190⁰ and touch 200 during aggressive driving. The mach also has front baffling which boxes in the front radiator. Read about the in-depth experimentation some guys have done with their GT's on the track. They've found radiator baffling to be one of the most important variables in managing engine Temps.
1. Larger cooler/radiator
2. Boxing the airflow in
3. Race louvers for the air out
If you look at Porsche, BMW, etc - they all use smaller coolers with very efficient air channeling into and out of the coolers. Same methodology with Brakes.
I have a 2018 A10 and my original trans also behaved differently than the warranty replacement I have now - I think the early A10's somehow are not as refined as the later models. I have driven 2021 A10's and they were very smooth, even smoother than my factory sealed replacement A10. My original was defective though, so I take that into consideration too.
I believe the solution for the radiator/engine thermostat would be to get an oil cooler or sandwhich plate with new thermostat set to 160-170F and tune car to turn on fans earlier.
