Driv3n to Dr1ve
- Feb 7, 2016
- Washington
- 2016 Mustang v6 6 speed manual
What are the specs on each driveshaft? The v6 driveshaft will shatter over 120 and I thought an easy solution would be to swap in an OEM GT driveshaft that is made for a manual with 3.55 gears. The manual is still the MT-82 so that seems simple enough. The only part I’m not sure of is if the v6 has a different differential from the GT, and any other components that may vary. I’m fine with doing any fabrication if it’s required.
