Supersnake on 18 Mustang
rtg
CT
Rob
2018 GT PP1+
I like but, I'm biased....
rtg
CT
Rob
2018 GT PP1+
I'm OK with it. Here are a couple other views if you are interested.....
Now I need to add your tail light tints.
Rob
BigWormGraphix
Gold Sponsor
Youngstown, Ohio
www.bigwormgraphix.com
Team BigWorm
>=2005 muscle cars - camaro, mustang, challengers
rtg
CT
Rob
2018 GT PP1+
Thanks for the code.
Added another view you may not have gotten.
Cheers
Rob
rtg
CT
Rob
2018 GT PP1+
Says "Your basket is not eligible for the specified coupon." Only have the "mus-18-19-tail" in the basket.
Thanks,
Rob
BigWormGraphix
Gold Sponsor
Youngstown, Ohio
Team BigWorm
Thanks,
Rob
Sorry about that, I forgot to update the new products. All fixed now.
rtg
CT
Rob
2018 GT PP1+
Ordered. Thanks!
Temovic55
Saudia Arabia
GT500 2014, ROUSH II 2018
Hey there! Sorry for commenting on an old post but I kinda wonder what mud flaps are those cause they look OEM to me ! Link please if you don't mind!
Thanks ahead
rtg
CT
Rob
2018 GT PP1+
Hi. I used the Mustang 15-20 Deluxe Rock Guards from ZL1 Addons. The key to keep them on well is to remove the rear wheels and thoroughly clean the inside of the wheel well. Expect loose paint. Light sanding with 150 grit helps a lot. This is where plastic blocks they give you to screw into holding the guards in place mount. Here is the key.... get some Gorilla Glue double sided tape and use that. It holds really well. Not sure if it matters but if possible let it setup for 24 hours before installing the guards. You can drill the blocks and reinstall the tires but install the guards 24 hours later if possible and let'r rip.
The tape they give you does not hold up. So I had to mount the blocks twice. The Gorilla glue has been solid.
They are a good add, I think. Keeps the sides from rock chips.
Rob
BlackStallion18
San Jose, CA
Justin
2018 5.0 Mustang w/Performance Package 1
I want to order the same ones but matte black to give a ghost stripe effect on my shadow black 2018
BigWormGraphix
Gold Sponsor
Youngstown, Ohio
Team BigWorm
3rdRGR
Indiana
Rick
2018 Roush RS2, 2011 Nissan Murano SV
Hi, I'm looking at replacing the outside (of the main center stripe) pinstripes on my Roush RS2, which has the Super Snake type center stripe. Although, mine look to be a little thinner than the ones above. I'm looking to match the "Roush" windshield script which looks to be a Silver of some sort. Do you happen to know (mine is a 2018) if either of your silvers match the Roush script?
