Thank you. Does the wing come with any mounting hardware? Because I didn't any.. What size studs or bolts do we use?Here's the method I used to install mine.
Take a small piece of paper and tape it to the bottom of the wing mounts. Don't use too much tape as your going to be removing it soon. Use a pencil or screwdriver to poke holes in the paper into the mounting holes. Position the wing on the car and line it up exactly where you want it. You will need a 2nd set of hands for this. Without moving the wing, untape the paper from the wing and tape it to the trunk lid. Now when you lift off the wing, you have a template showing you exactly where to drill.
I also used studs in place of the mounting bolts. That made it much easier when it came time to line it up the holes when bolting it on.
I do believe it comes with hardware. I don't remember the size. Best guess would be 1/4-20 or 5/16-18.Thank you. Does the wing come with any mounting hardware? Because I didn't any.. What size studs or bolts do we use?
wow.. let's forget the hardware... I am in deeper shit now... After prepping and painting the wing, I find out it is a 14 mustang wingMine came with all needed hardware.
Black - just got your private message. Let me look into your order & see what I can figure out - I don't have access to the systems tonight but I will have this looked into first thing in the a.m. - including letting our leadership team know.wow.. let's forget the hardware... I am in deeper shit now... After prepping and painting the wing, I find out it is a 14 mustang wing
Black, can you send me photos of the wing you received?wow.. let's forget the hardware... I am in deeper shit now... After prepping and painting the wing, I find out it is a 14 mustang wing
Email sentBlack, can you send me photos of the wing you received?
Thank you,
TJ
Tim,Black, can you send me photos of the wing you received?
Thank you,
TJ
Ouch.wow.. let's forget the hardware... I am in deeper shit now... After prepping and painting the wing, I find out it is a 14 mustang wing
