Steeda In Stock!
JakeLethal
Wellington, FL
Jake
2022 F-150 RCSB 5.0
Hey. Everyone!
We just got a fresh batch in from Steeda Autosports here at Lethal Performance!
From favorite first mods, such as their Progressive Lowering Springs, Resonator Deletes, and Sway Bars to their more in-depth mods such as toe links, bushing kits, camber plates, struts, and more, weā€™ve got everything Steeda for your Mustang.
Check out some popular picks here:
Steeda ā€˜Stop the Hopā€™ Street Ultimate Kit (2015-2024 Mustang) - 555-2129
Package Includes:
  • 555-4437 - 2015 Steeda Mustang IRS Subframe Bushing Support System
  • 555-4438 - 2015 Steeda Mustang IRS Subframe Alignment Kit
  • 555-4121 - 2015 Steeda Mustang Billet Aluminum Vertical Links
  • 555-5754 - 2015+ Steeda Mustang IRS Subframe Support Braces
  • 555-4120 - 2015+ Steeda Mustang Adjustable Rear Toe Links
Product Benefits
  • Improves vehicle handling
  • On-car toe adjustability
  • Improves suspension compliance
  • Increases traction
  • Aligns subframe to chassis
  • Limits IRS sub frame movement
  • Reduces wheel hop
  • No added NVH
Full details here: https://www.lethalperformance.com/s...-ultimate-kit-2015-2024-mustang-555-2129.html
Steeda Sport Lowering Springs Mustang - Progressive (2015-2023 Mustang GT / V6) - 555-8210
  • Lowering 1.125" in front and 1" in rear
  • Clears 20" wheels
  • Great ride quality, improved aerodynamics and improved vehicle stance
  • Sharper steering response, improved vehicle handling and stability, noticeable reduction in nosedive.
  • Fits coupe and convertible (with rear spring spacer)
Full Details here! : https://www.lethalperformance.com/s...ressive-2015-2022-mustang-gt-v6-555-8210.html
Steeda Clutch Spring Assist and Spring Perch Kit (2015-2023 Mustang) - 555-7027
Your 2015+ Mustang GT comes with a 185 lb/in clutch assist spring installed from the factory. This high-rate spring is what causes such a vague and disconnected clutch pedal feel.
  • Improve clutch pedal engagement feel
  • Consistent spring rate and minimal sag even after repeated use
  • More linear clutch feel
  • Heavy Duty design thatā€™s guaranteed for life
  • Avoid slave cylinder damage due to removal of stock clutch spring
  • 100% Made in the USA, in house in Valdosta GA
Full Details here: https://www.lethalperformance.com/s...ing-perch-kit-2015-2023-mustang-555-7027.html
Interested in upgrading your carā€™s handling but not exactly sure where to start? Check out out blog page on our ā€œSteeda Editionā€ of our Lethal Performance Suspension Packages, where we worked with Steeda on designing a perfect level-by-level system of upgrading your cars suspension for your specific purpose.
SHOP NOW | ā€œSTEEDA EDITIONā€ - LETHAL PERFORMANCE SUSPENSION PACKAGES
Check out everything Steeda for Mustang here!
SHOP NOW | Steeda Autosports
As always, if you have any questions or need some help in finding your Steeda mods, reach out with anyone of us here at Lethal Performance!
