Steeda 2 point or 4 point brace ?
ANGST
Herndon VA
18 Cayman GTS, 15 Explorer Sport , 09 Honda Fit
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
I have the 2-point version. I am not super handy, so the 2-point is easier to install and lighter. With my vert, it feels stiffer around country roads. I do not race it and I have the upper strut and K-braces installed from the factory, so I do not see the need for the 4-point.
Your needs may vary.
Thanks
CVCashmere
Nagare
Ft Lauderdale
2017 Lightning Blue V6
When I asked for a comparison between the two, Rodney at Steeda summed it up as: if there is nothing blocking the install of the 4 piece, get the 4 piece. It'll add more stiffness.
If I were to order one, probably the two piece though, just for ease of install.
Memphis-EcoStang
Vancouver, WA
2016 Impact Blue Ecoboost
If you are already low enough you have to go over speed bumps sideways.... go with the two point it has slightly better ground clearance.
Otherwise go with the 4 point and have fun banging on those damn spacers to get them in. I highly recommend band aids and bourbon to wrap up the install. Results wise, the four point definitely tightens up the front noticeably and is really worth the money/bruised knuckles. Cant speak for the two piece.
tj@steeda
Timothy
Yes, what they said above - let us know if we can help, call Rodney at 1800 950 0774 - he will take care of you.
Best Regards,
TJ
Daytona Coupe
Central CA
2015 GT, 2017 Explorer Sport, Ducati Diavel
I went with the 4-point and it was a piece of cake to install, but I was doing it with the car on a lift. I don't think it would be any trouble at all without the lift though. The 4 has to be stiffer, so I'd recommend that.
ANGST
ANGST
Herndon VA
Yup I have a lift , going to use it to install my tow hook on Friday ;)
Donyw
Long Island NY
Donnie
I did it last weekend on jack stands. 4 point. Was no big deal other then popping out the metal plugs left from where ford punched the holes in the frame. Had to take a file to the spacer to shorten them a bit. Car is much stiffer up front in corners. Very happy. Easy install.
tj@steeda
Timothy
Appreciate the feedback!
TJ
