firestarter2
How is the angle out of range?Because it's missing the seats, the angle is out of range when you do this. Because of that reason, I used the child seat anchor points and bolted in the buckle/bolt.
You'll find that when you take the delete off, none of the hardware to mount the belt/buckles in are there. I have the parts list to do it. They're self tapping bolts however, so that part is easy. Install is fairly simple.
I do plan on moving up to the Watson though. It will be a cleaner look, stiffen the chassis, and end up being a better mount for harnesses and HANS.
And let's be honest - there is no better place to mount a GoPro.
Just buy one stock belt connector and bolt it to the stock location. Bolt the male buckle they provide to the stock location and your done. I find it hard to believe the R is missing the holes for the stock belts at most you probably need 2 bolts.
Does the Watson stiffen the car?
