Best looking stock mustang I've seen:ford:My RC PP2 from todays local Cars and Coffee
Very beautifulHere’s a photo I took of our friend’s beauty after installing the cervinis grille.
Very beautiful
What's done to do it besides I'm guessing, wheels, lowered, tint, marker tint, grilles&stripes?
I like that badge on the grille to helps break up the large opening. How was the overall installation process?
I'm about to put my modified upper gt grille&ram air scoop on my eb later today. So any real world tips would be helpful:hail:
Funny you should mention that. As I actually modified the grille by cutting away all the honeycomb except for the pony with it's corral. Hoping it's gonna look good&be different to should have it done later today, will post a few pics if I like how it ends up turning out:shrug:I think Airaid intake tube and k&n drop in filter. The install took longer than normal because it does not use the stock clips. You have to screw in a bunch of plates around to hold in place and the mesh is screwed in too. Other than that all good.
Modified GT grille? Interested to see since I’m looking into doing something similar for the wife’s OF Eco because she wants the floating pony.
Awesome! I’ll be waiting for itFunny you should mention that. As I actually modified the grille by cutting away all the honeycomb except for the pony with it's corral. Hoping it's gonna look good&be different to should have it done later today, will post a few pics if I like how it ends up turning out:shrug:
Here's some pics. Stock gt grille opened up to leave only the pony in it's corral. Lower opened to match the upper, side pockets opened to match the actual scoop size. Velossatech ram air scoop in gloss black to match grille(first ever on a 2018.:ford:
Can confirm that after a quick test drive&a few hard pulls. Per in car sensors intake air stays within 2-5degrees of ambient temp. Before it would be as much as 20degrees over ambient in an type of idling or stopped situation. Even moving it wouldn't get this close to ambient. Imo worth the $ not sure other then a little added turbo spoiling up noise under full throttle. What it actually offers perf wise:shrug: best guess would be slightly better mpg on long trips&possibly a tenth or so at the strip.
Painstakingly cut the honeycomb sections out with a dremel&cutting wheel. Leaving just the center mounting honeycomb part left. And then used sanding discs to smooth everything into some semblance of acceptable. Covered over all the nicks&stuff with a black sharpie:lol:Looks good! You should delete the shutters. How did you get the pony to float?
Ok, i’ve done the delete part just wondering how you kept the piny floating. Thank you! Looks really good!Painstakingly cut the honeycomb sections out with a dremel&cutting wheel. Leaving just the center mounting honeycomb part left. And then used sanding discs to smooth everything into some semblance of acceptable. Covered over all the nicks&stuff with a black sharpie:lol:
Thanks for the props
Going to be a rare colour for sure, especially here.Ordered March 28th. Out of 'order processing' and 'in production'. Got the window sticker today. Has to travel from Flatrock to west coast of Canada. EDD is June 7th. Have yet to see a Royal Crimson GT Premium on the road in this part of the world.
Awesome i ordered mine the same day. Still in order processing, but I have a VIN and build week is june4. Can’t wait!!!!!Ordered March 28th. Out of 'order processing' and 'in production'. Got the window sticker today. Has to travel from Flatrock to west coast of Canada. EDD is June 7th. Have yet to see a Royal Crimson GT Premium on the road in this part of the world.
