How did you tighten that bolt I can't access with a slim socket and how much did you torque?My rear end passenger side suspension has developed a creak when moving forward from a stop.
I've dealt with a similar issue to a greater degree on the driver side rear at one point however i was able to fix it.
When it was my driver side the issue was taht this bolt circled appeared to be loose and tightening it solved the problem
My assumption is that the passenger side is having a similar issue since the noise is similar, however i was unable to tighten the bolt.
Any ideas would be greatly appreciated.
Thanks,
Brant
