Read Maximum RPM from OBD2 or?
boB
boB
2019 GT PP1
I am hoping to find the maximum RPM (and temperature) reached by my car. I tried OBD2 reader and Forscan but could not find the information. I suspect Ford logs this data somewhere but maybe it is not recorded.
Any ideas?
KingKona
Virginia
Shlomo
2019 GT
I would expect that it's not recorded. The car has a hard-stop rev-limiter, so there's no reason to do that.
WD Pro
United Kingdom
Lime GT
Hard-stop rev limiter means nothing in a manual with a miss shift … :frown:
WD :like:
boB
boB
boB
2019 GT PP1
WD :like:
:) I didn't miss a shift but did run it up to about redline in 4th for a bit (repeatedly). Just wondering how I can find just how high the revs went.
WD Pro
United Kingdom
Lime GT
Yeah I wasn’t suggesting that, my response was to kingKona’s comment :like:
I would actually like to know the same thing as I’m pretty sure the digi dash has a noticeable lag, especially in the lower gears where the revs climb rapidly :like:
WD :like:
Andy13186
If you have android you can download the torque app and have it record max RPM from an OBD2 if you set it up right. At least I could on my 09 CTS-V with this app and a bluetooth obd2.
Here is what my torque app setup looked like.
I just use my nguage on my mustang and look at the logs after.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Which OBDll Adapter do you use for that app?
Andy13186
kz
West Chester, OH
Mustangs & F150
If you are looking for a history, highly doubt it is being recorded and if it is - it's not easily accesible. Get an OBD2 reader with any kind of app that can do logging and re-do it.
boB
boB
boB
2019 GT PP1
So, did you blow it up?
Nope, it ran around Daytona perfectly then cruised home at about 60 mph less. ;) From the in-car video it looks like it was just a bit above 7000 rpm, no problem.
boB
boB
boB
2019 GT PP1
That's a great excuse to take it on a track again! ;)
RagmopInKona
CEO
2020 Mustang HHP
Why in 4th gear if on the high banks? Did they limit how much lead you could let out.
speedydave
hickory, NC
2020 GT PP1 Oxford White
4th tops out the speed limiter before it red lines (Around 6,800 from what I have seen). No real gain in going to 5th.
boB
boB
boB
2019 GT PP1
First time at Daytona so I was learning the car and track and not wanting to push it, 140 was enough. But next time... ;)
