- Dec 4, 2013
- Romansville, PA
- Website
- www.evoperform.com
- Fred
- 2021 Shelby GT500
"BRAND NEW" - Part# JJ-21217 - QA1 Driveshaft Carbon Fiber REV Series One-Piece SFI Approved - 2018-2020 Mustang GT with an Automatic Transmission.
TWO (2) IN-STOCK, NO Waiting...!!!
$1,400.00 - FREE SHIPPING...!!!!!
QA1 SFI Approved REV Series One-Piece Carbon Fiber Driveshaft for 2018, 2019 and 2020 Mustang GT's with an Automatic Transmission.
If you're turning your all-new 2018-2020 Mustang GT into a true race machine, than you'll want to cut weight and improve performance with this superior QA1 SFI Approved REV Series One-Piece Carbon Fiber Driveshaft (JJ-21217)
QA1 Driveshaft Features
- Direct-fit upgrade for 2018-2020 Mustang GT with an automatic transmission
- Certified to meet SFI 43.1 specifications
- Outer diameter measures 3.30"
- 3M Matrix Resin for ultimate torque capacity
- Superior carbon fiber construction is 50% lighter than stock and stronger and safer than steel or aluminum
- Harmonic tested to ensure it meets NVH requirements
- Torsion tested and serialized for improved capacity and longevity
- Smooths out RPM spiked during launch and shift points
- Provides increased traction and better safety
- Wear resistant and durable
- Quick and easy bolt-on installation
- Made right here in the U.S.A.
*This driveshaft will only fit 2018-2020 Mustang GT's equipped with an automatic transmission.
This brand-new upgraded driveshaft is the perfect upgrade for your newer pony if you're looking for a lightweight, race-inspired option! QA1 designed their superior driveshaft to withstand extreme racing environments. The lightweight carbon fiber construction will extend the life of your transmission and differential while providing quicker acceleration and more power to the ground. QA1 uses their exclusive 3M Matrix Resin to help ensure your Mustang reaches ultimate torque capacity under the most taxing race conditions.
The QA1 Driveshaft features a built-in surface protection in the tube to withstand extreme racing conditions. Carbon Fiber is a strong, upgraded material that helps with weight savings, will provide quicker acceleration and plants the power to the ground. By controlling the torsional stiffness of this one-piece driveshaft, QA1 has achieved more twist to smooth-out torque spikes, resulting in increased traction during launch and shift points. QA1's driveshafts use solid U-joints and have been subjected to various tests to meet SFI's 43.1 specifications for safety and performance, proving their extreme strength and durability.
Please Note: Does not fit 2018 Ecoboost or Shelby GT350 Mustangs.
