jacknifetoaswan
- Jan 6, 2016
- Charleston, SC
- 2016 Race Red Mustang GT Premium Performance Pack
Sunday morning, I pulled the front of my car apart to install my Big Mouth, as well as my 2018 airbox and intake tube. I pulled off the stock 2016 intake tube, then realized that I had not accounted for the fact that the 2016 has two vacuum connections (in addition to the sound tube), while the 2018 has one vacuum connection. Since I'm not ready to swap in my 2018 intake manifold, I put the 2016 tube and airbox lid back on, but left the 2018 airbox bottom in the car. I inadvertently broke the two clips that hold the vacuum lines onto the intake tube, and didn't think anything of it. I started the car, and everything was fine.
I did not drive the vehicle yesterday.
Today I started it, drove about 10 minutes at highway speeds, parked, and went into a store. I came back out about ten minutes later, and upon starting the car, it stumbled a bit at 700 RPM, dropped to about 400 RPM, then stabilized. It didn't seem to have a rough idle. I drove to another store, sat on a conference call for about 30 minutes with the car running, then went inside. Upon starting the car again, it stumbled, but then stabilized. I pulled out of the parking lot, went to get back on the highway, and saw the CEL on.
When I got home, I read the codes, and got:
P0171 - System Too Lean (Bank 1)
P2197 - O2 A/F Sensor Signal Biased/Stuck Lean (Bank 2 Sensor 1)
I cleared the codes, put new vacuum hose clips on, then started the car again. Again, the car stumbled slightly. I sprayed carb cleaner all over the connections I had disrupted, but didn't get a surge from a vacuum leak. I haven't driven the car since then, and I'm a little worried to do so.
Thoughts?
JR
Thoughts?
JR
