UnhandledException
I bought all these cars new. I babied the M3 and M5 and followed the break in to the letter from the manual. With the shelby I didnt. The first 50 miles I kept it around 4000. Then took it to 6000 a few times till 150 miles and from that point on 1000 more every 50 miles. I hit 8250 by 250 miles. But I didnt redline it off the lot with 5 miles. Should I have done that?Did you buy your M5 new, also? If every high-revving engine you own has consumption issues, there could be a problem with your approach to break-in.
Re. catch can, there are thousands of Voodoos running around with catch cans with no consumption issues. If it was related to the cans you installed, it would most likely be an installation issue and/or a failure with the unit you installed. I still maintain you were creating some kind of siphon effect to pull oil out of the crankcase. Failed oil separator diaphragms on some cars (BMW M54 and M62 engines, for example) can do the same.
What is the purpose of engine braking? Driving the car hard doesn't require engine braking from high RPM. That can create high vacuum that's likely to pull oil past the rings, especially if the rings weren't seated well during break-in. On track, you run the engine hard but you slow the car with the brakes, which exist for that purpose.
I'm at ~3500 miles, mix of highway, hard street running, virtually no city miles, and track. I have consumed about 1/4-qt of oil total.
With the way I drive, just in general, I tend to hold low gear so that I can accelerate quickly if the need arises. But I have been changing that or trying at least in the last 1500 miles. But I m not like the other poster, I dont bounce it off the limiter on a daily basis.
Its hard not to accelerate to 4000 rpm and let go off the gas just to hear the engine. Its addictive to be honest.
