Just got new wheels on my car and the fronts are tucked in a little too much for my liking they are a 20x8.5 25 offset and i was wondering what size spacer i should run to get it out closer to the fender
You HAVE to be sure that the wheels you have can accept spacers due to the pockets in between the lugs. Chances are if you run a factory wheel you're good, but many aftermarket wheels do not have the cavity necessary to fit spacers. Most common is the 25mm spacer which is just shy of an inch.
