Grimreaper
Jumped to a blower and no longer have a need for these parts. All parts were bought new from vendors less than 2 years ago with less than 10k miles on them.
MY18 manifold, includes VMP pigtails to keep the IMRC working. also includes pigtail and evap purge valve and matching line from a 2018 for a stock looking install. pigtails and evap setup is $200 extra alone. evap bracket modified to fit to fuel rail. light sanding/porting on intake runner throats to clean up the mismatch that happens when the manifold is assembled at factory. can send out for more porting or run as is.
$330+ shipping. box is 36x16x15 at 24 lbs SOLD
GT350 intake and Throttle body. Includes port matched adapter to use TB on stock or my18 manifold. also includes silicone coupling ring to mate stock TB to gt350 intake. Has 2 air filters, 1 stock , 1 JLT blue oiled. has been cleaned and re oiled 1 time. Oiled air filter is $70 new. will need to buy oiling kit from S&B. Locating tabs at the air box connection have been removed to allow it to rotate and not bind when using on my18 manifold. fits just like stock. fabbed a clear plastic 'lid' to keep iat's down, added a honeycomb air straightener just after filter which improved signal quality in logs.
$240 +shipping. box is 27x20x19 at 21 lbs SOLD
Ford Performance LU47 injectors. zero issues, worked perfectly on e85 and gas. pulled a week ago.
$190+ shipping. box is 10.5x8.5x7 at 1 lb 10oz SOLD
shipping is from 75007 or can meet if local.
