The problem with the stock intake system is that it is restrictive and heat soaks because of its close proximity to the engine.. Dropping a K&N filter will provide some improvement but lets look at the stock airbox... The only way for air to enter the engine is a small intake no bigger then a 2.5-3" pipe. From there the air has to turn 90 degrees to move up through the stock air filter. After the air filter it must again turn 90 degrees to move through the intake tube and then again another 90 degree turn before the throttle body. The key is much like an exhaust system, free flowing straight design while still providing filtration for the engine. This is where the Cone filters and cold air intakes come into play. And a well placed filter with a heat shield should have minimal problems with sucking in warm air.Wouldn't we be better off with a K&N (or other aftermarket) drop in filter. Doesn't the factory air box get it's air from tubes/pipes under the box that divert cooler air from the front of the car? It seems that putting an open air filter in the engine bay would just be a vacuum for hot air.
How's delivery coming along, Zack?The problem with the stock intake system is that it is restrictive and heat soaks because of its close proximity to the engine.. Dropping a K&N filter will provide some improvement but lets look at the stock airbox... The only way for air to enter the engine is a small intake no bigger then a 2.5-3" pipe. From there the air has to turn 90 degrees to move up through the stock air filter. After the air filter it must again turn 90 degrees to move through the intake tube and then again another 90 degree turn before the throttle body. The key is much like an exhaust system, free flowing straight design while still providing filtration for the engine. This is where the Cone filters and cold air intakes come into play. And a well placed filter with a heat shield should have minimal problems with sucking in warm air.
It will have a lower inlet in the final version. Had to build it this way because of the material I used. Tomorrow I will be building another/modifying this one to use less material and have that inlet. I think in the end I will just have the bottom, back, and side around the filter neck.Needs a lower inlet (unless the opening you're showing is going to face down).
Either Sheet metal (12-16 gauge) or a material called PVC foam. PVC foam is basicly PVC plastic that has been extruded into a sheet much like they do with foam sheets. It is porous, "lightweight", and a good insulator. The PVC foam is easier to work with and I already have some so I will probably be going this route first.What material are you planning on using to do the filter housing/ heat shield?
Thats the plan... Avoid metal as much as possible. Plus I already have 3 sheets of the PVC foam from another project.Don't use metal if you can help it. Metal will act as a heat soak and could raise IATs, rendering your work ineffective.
http://www.americanmuscle.com/hp-heatshield-mat-24in.htmlThats the plan... Avoid metal as much as possible. Plus I already have 3 sheets of the PVC foam from another project.
I think I have the mounting points determined for the heat shield. One bolt through the bracket in a previous picture and then a flange holding the shield to the intake tube. Should be enough to hold it in place but I have a third mounting location in mind just in case.
I could but that would probably be overkill... I'm thinking the PVC sheet will work. I just need this damn coupler to arrive now to proceed with the project...!http://www.americanmuscle.com/hp-heatshield-mat-24in.html
What about sticking this around whatever you end up using?
