Modifying As-Built Data Guide
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
Crusch84
Pittsburgh
Sorry guys but there are 193 pages lol is there a link to the most current revision of the as built data sheet?
hlh1
Central VA
2019 GT PP1 A10
Post #3 has a link in his signature.
hlh1
Central VA
2019 GT PP1 A10
Thank you! I just wasn't sure if it was revised as things get updated
Good point. We'll see if someone else gives us an updated version.
Chappers
Sutton Coldfield, UK
Greg
Toyota Supra MkV - Tungsten Silver
Replaced analog cluster with digital on a 2016. For whatever reason, the fog light indication on cluster does not show up when I turn on fog lights. Is there a fix for this? Low and high indications show up on the cluster. Thanks.
try changing:
Front Fog: 720-01-02 xxxx *xxx to a 1 if you have front collision warning you need 7 this will add front fog tell tale
Rear Fog: i think, 720-02-02 xxxx xxx* xx to a 2 "enabled" with forscan instead of going to "IPC (As built)" go to "IPC" i think the recent update has the option to select "rear fog telltale" set that to enabled this should give you the rear fog indicator.
ILStang
lllinois
20 GT Premium, Oxford White
Anyone get the fog lights and brights on at the same time in a 2020 yet? The values on the spreadsheet didn’t do anything.
Epiphany
Global
I like to disassemble things.
Not sure if this has been shared yet, found in another forum.
GT500 (Mustang EVO) Splash Startup and Shutdown:
7D0-02-01= xxxx 10xx xxxx
7D0-03-01= xxxx x0xx xxxx
You sure that's right? I just looked at those two addresses for my 2020 GT500 (a Base) as well as a CFTP GT500. They show:
7D0-02-01= xxxx 10xx xxxx (same as what you showed above)
7D0-03-01= xxxx x1xx xxxx (the 0 you showed comes up as a 1 on both GT500's that I looked at)
MustangNewbie
Port Hedland, Western Australia
Rick
2019 Ruby Red Mustang GT
So you never got the GT500 splash screen to work on version 3.0?
Ford added several new splash screens in Version 3.2 (I think it was that). The Mustang EVO splash screen was one of those. I regularly check for Sync3 updates :) I have that splash screen on my MY19 GT. But I don't remember the exact coding for it.
PizzyP
Southern California
Patrick
2019 Mustang Bullitt
The 2019 Mustang Bullits have an image of the car in the digital dash when starting up the car, is it possible to find that code and put it so the same image is what appears in the splash screen enter/exit?
MustangNewbie
Rick
I'd think it's possible, but I have no idea what the coding is for it. It's likely that someone knows it
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Played around with the settings on my digital cluster swap this morning and realized I don't have the options for the colors. Anybody got an idea on which line needs to be changed and to what for that?
I'm thinking it might be the MyColor line from previous years, but given that this is for a 18+ car not certain...and I can't open the Google Sheets link at work.
