It's not the threads, it's the rubber o-ring on the cap. I have a Moroso tank and have to use a little silicone grease on the o-ring when putting it back on.I also have super tight threads. You need a wrench to get the cap in and off.
Thanks for the input. On the stock tank, it screws right on and off with ease. Even with the O-ring removed, I have to use gloves and excessive force to get the cap on and off. It can be done then, but it would cut my hands without the gloves and is very difficult. Put the o-ring back in and you need pliers. These should have been resolved in Design. Both the threads are too tight and the inner diameter of the neck finish where the o-ring contacts may be too tight. It should go on and off like stock. That is my expectation as a customer. On the product page it states "Fits with stock overflow tank cap." There is no fine print that says it will take pliers to put it on or take it off. That cannot be acceptable functionality. I'm a Mechanical Engineer (4 years Navy, 5 years college/B.S. in Mechanical Engineering, and 8 years subsequent design + program management experience). If I designed this neck finish, you wouldn't need grease, gloves, and pliers.It's not the threads, it's the rubber o-ring on the cap. I have a Moroso tank and have to use a little silicone grease on the o-ring when putting it back on.
