HappySquirrel
W85 Whale Oil Tune
- May 28, 2015
- Las Vegas, NV
- Richard
- 2016 Mustang EB PP CO, 97 Pathfinder 4x4
- Vehicle Showcase
- 1
Hey guys,
A couple of months ago I lowered my car with a set of springs which are supposed to give a slightly forward raked stance. Unfortunately, it didn't work out and I have a very lopsided ride with a forward raked stance on the left side and a rearward raked stance on the right! I'm not going to mention the brand of springs at the moment in case the issue isn't actually with the springs (and I don't want to be accused of slander, etc), although I imagine most of you can figure out what springs I bought. I am at a loss to figure out what could be causing the issue other than incorrectly manufactured springs. However, I didn't have the foresight to measure the springs before installing them (I really didn't even consider this being an issue), nor did I measure the ride height before lowering the car (wish I had). I did the install myself, and here are the current ride heights measured from the ground to the top of the fender well (measured to a precision of approximately 1/16"):
Right Front: 27.5"
Right Rear: 27"
Left Front: 27.25"
Left Rear: 27.5"
As you can see, that's a problem. I don't expect springs to be manufactured to aerospace tolerances, but the fact that the right side is so far raked in the wrong damn direction really pisses me off. Does anyone have any suggestions on how to check if the springs are causing the issue without disassembly? Anyone have any ideas on how to fix the problem (besides changing to different springs or coilovers, or using dangerous methods like heating the springs)?
Any help would be appreciated, and now I will try to head off any obvious questions before they are asked:
1.) The car was aligned about 5 days and 100 miles after installing the springs. I also paid the alignment shop (local guys) to loosen and re-torque all of the suspension points suggested in the 6G suspension re-clocking thread while it was on the drive-on lift, and they said they did so and re-torqued to the appropriate values.
2.) I measured the ride heights on a flat surface, multiple times. I also measured from the wheel center cap to the top of fender and the results matched. I measured on multiple surfaces and I made sure the tires were aired up to within 1 psi of each other. Measurements were taken before and after the alignment and re-clocking and there was no significant difference.
3.) Spring installation was done by myself. Other than the springs the suspension is completely stock.
4.) I did my best to triple-check all phases of the installation. I was very careful about checking the spring seating and the seating of the rubber boots. I also double checked the front sway bar connections and everything else. I'm 99% sure I didn't screw up anything with the install (the car rides great, other than being lopsided).
5.) I did contact the spring manufacturer after the install and they basically said (paraphrasing slightly), "1/4-inch of difference is normal even for factory springs, make sure you drive it for at least a week, re-clock the bushings", blah blah.
6.) I did the install over two months ago and I've put well over 1,000 miles on the car. Just re-checked the ride height measurements, no change.
Like I said, any helpful input is appreciated. I am not a happy camper.
Right Front: 27.5"
Right Rear: 27"
Left Front: 27.25"
Left Rear: 27.5"
