J&M Products / Hotpart.com Newest Parts - GT350 & GT350R Specific Stainless Steel PTFE Lined Brake Hoses
Hotpart.com
San Luis Obispo, CA
2002, 2006, 2015 Mustangs
2015-2020 Stainless Steel Brake Hose Kit Front GT350 & GT350R – Clear Cover
Part # 22580FC
Fits: 2015-2020
Ford Mustang GT350 & GT350R
J&M Products direct fit D.O.T. certified PTFE lined brake hoses. These brake hose assemblies use true OEM style direct replacement non-universal fittings to achieve proper factory hose routing and fitment. Expansion of stock rubber hoses causes a spongy brake pedal feel and loss of initial braking force. Installation of our PTFE-lined stainless steel hose assemblies will give your car a firmer pedal, quicker braking response, and easier brake modulation. Hoses are tested to 3000 psi to guarantee a leak free hose assembly. Best of all these are made by J&M Products right here in the USA.
Stainless Steel Features and Benefits:
  • Direct OEM Fit each fitting is of OE design so NO adapters are necessary.
  • No volumetric expansion (hose swelling) for powerful braking and amazing ‘feel’
  • Suitable for all applications including extreme racing.
  • Exceeds the latest DOT standards backed up by independent laboratory reports.
  • Trivalent zinc plating exceeds DOT salt spray test.
  • Design allows high temperature operation and longer life.
  • Every hose is pressure tested to 3000 psi. (207 Bar)
  • Quicker brake response. Better brake modulation.
  • Every hose is stamped with U.S. DOT registered number.
  • Clear Outer protective covering.
Fits: 2015, 2016, 2017, 2018, 2019, 2020
