Only the pumpkin comes in different alloys (aluminum or iron). The cover is aluminum for all of them which is why you don't see rust. Yes you have the stronger one, but only in the mounting sense eg. the ears that mount it to the chassis is where it usually fails. The differential itself inside is not any stronger than others.So this is the stronger one? I was looking for the cover to be rusted
Exactly. Lifting the car puts the diff bushings in shear from a few hundred pounds of the rear suspension/wheels/cradle/etc. And it's not good to use a jack as a stand, unless it for just a moment and never when you're under the car.I think some of the concern with jacking up an IRS rear (like the S550) from just the pumpkin is that the weight of the vehicle is now on the rear diff flanges and associated mounting bolts.
yeah i mean why don't you guys just get two post lifts?Why don't bite the bullet and bring home a QuickJack? That's the safest and quickest way to lift the car, the only drawback it's the cost.
Yesbrb, installing a lift in my apartment parking lot
on a serious note, I can just jack on the yellow and jackstand the red jack pads right
That jack adapter can lift the whole rear. It is rated for 4000lbs (3000lbs fully extended). I use it if I just want the back of the car in the air. Pump the jack and add jackstands in front of the rear wheels on the jacking rails. Remove the jack.I have a similar jacking system as what is pictured installed on that jack above, and that I can use to lift the rear subframe if I have to disconnect anything, but that is used once the car is already in the air. It's not meant to lift the car BY that system alone. It's meant to lift sub-components UP to where the car IS. It's essentially a glorified transmission jack.
Yeah. Which is why I'm surprised Ford says its a jack point.Exactly. Lifting the car puts the diff bushings in shear from a few hundred pounds of the rear suspension/wheels/cradle/etc. And it's not good to use a jack as a stand, unless it for just a moment and never when you're under the car.
Lifting the car with the diff puts those bushings in shear with a couple thousand pounds from the weight of the car.
On rare occasions I will lift the rear of my car from the center using a jack under the diff. But either I keep the session super short (a minute or two), or I put some jacks stands back there and let off on the jack.
Do they though? There is nothing in the manual about alternate jacking locations.Yeah. Which is why I'm surprised Ford says its a jack point.
