GT Pony
- Mar 13, 2015
- Pacific NW
- 2015 GT Premium, Black w/Saddle, 19s, NAV
Like I said ... the voltage will be "all over the place" because the "smart charging system" is trying to control the charging voltage based on inputs to the computer system. This charging system is not like the ones made 20 years ago where the charging voltage remains constant. I've seem mine anywhere from 12.7 to 14.3 volts. If you watch it on the dash while driving around you can see it fluctuate some.Well, when I was in for warranty work late May for idle issues I had them check the battery. It was all over the place on voltage 12.1-14.9. They said it was good?
Here's a descrition of the charging system in the S550 Mustang:
General Information
The PCM controls the voltage regulation setpoint and communicates this information to the generator internal
voltage regulator over a generator communication (GENCOM) communication circuit. The PCM receives
generator load and error conditions from the generator over the generator monitor (GENMON) circuit.
The PCM monitors the generator current using the generator current sensor attached to the generator B+ battery
cable. The information supplied to the PCM from the generator current sensor is used by the PCM to adjust the
engine idle stability and torque control.
Charging System
The PCM controlled Smart Charge charging system determines the optimal voltage setpoint for the charging
system and communicates this information to the voltage regulator. The Smart Charge charging system sets
Diagnostic Trouble Codes (DTCs) when a charging system fault is present. All of the Diagnostic Trouble Codes
(DTCs) can set continuous faults, but not all Diagnostic Trouble Codes (DTCs) set as on-demand faults.
This system uses 2 communication lines between the PCM and the generator/voltage regulator: A generator
communication (GENCOM) line communicates the desired setpoint from the PCM to the voltage regulator, and a
generator monitor (GENMON) line communicates the generator load and error conditions to the PCM. Both of
these use PWM. The PCM sends the GENCOM command only when it is necessary to adjust the voltage
setpoint. If the setpoint does not need to be changed, several seconds may elapse between PCM GENCOM
commands. This normal operation appears in the PID as occasional bursts of pulse-width commands. In addition
to these two circuits, a third pin on the voltage regulator, the "A" circuit pin, is dedicated to monitor, or sense, the battery voltage.
The PCM simultaneously controls and monitors the generator output. When the current consumption is high or
the battery is discharged, the PCM raises engine speed as needed to increase generator output. The generator
charges the battery and at the same time supplies power for all of the electrical loads. The battery is more
effectively charged with a higher voltage when the battery is cold and a lower voltage when the battery is warm.
The PCM turns off the generator during cranking to reduce the generator load and improve cranking speed.
Once the engine starts, the PCM slowly increases generator output to the desired voltage.
The PCM reports any charging system faults and sends a message through the High Speed Controller Area
Network (HS-CAN) to the BCM. The BCM controls the charging system warning indicator by sending a message
over the Medium Speed Controller Area Network (MS-CAN) to the IPC. The IPC then controls charging system
warning indication based on the message from the PCM through the BCM. The status of the PCM charging
system warning indicator and/or message is confirmed by viewing PCM PID generator fault indicator lamp
(GENFIL). Any charging system fault detected by the PCM results in 1 or more Diagnostic Trouble Codes
(DTCs) being set and the PID GENFIL having a status of On. If equipped with a charging system warning
indicator, the IPC turns the indicator on or off. If equipped with a message center, the IPC displays a CHECK
CHARGING SYSTEM message. In some instances, the CHECK CHARGING SYSTEM message may not
display if the ignition is on and the engine is off.
Under certain circumstances, the charging system may have a concern but still keeps the battery charged and
the vehicle running. GENCOM normally initiates charging but with a fault in this circuit, the generator can
self-excite and start charging on its own. The charging system warning indicator is illuminated and/or the CHECK
CHARGING SYSTEM message is displayed, and the generator operates in a default mode (approximately 13.5 volts).
