asci01
When drilling the holes, don't put pressure on your drill and use a variable speed drill. Use the lowest speed. The plastic of the bumper is very soft, so the drill bit will have no problem cutting a hole. As you know, you can always make the hole bigger but it's very hard to make it smaller if you cut too much.
When programming PAM 736-01-01, use '5' on the 3rd digit if you have an automatic, otherwise use '4"
