IAT Info for Lethal Performance's Gen 5 Whipple with a PNR Ice Tank
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
We got some solid data that we felt you guys would be interested in seeing. This data comes from our 2018 Mustang GT 10 Speed Auto with the Whipple Gen 5 3.0L Supercharger.
The car currently runs a 3.50" upper and 20% lower which should make close to the 20psi range.
Here's a log of the car when I went [email protected]. This is with the standard heat exchanger and pump that comes with the Stage 2 Whipple kit.
The next log is from last week when I went 8.98@150+. This was using the PNR Ice tank with just water in it. No Ice, No whipple reservoir and no whipple IC pump.
The last log is of my 8.97@151+ run. This is with the PNR tank with 2 10lb bags of ice in it. No Whipple reservoir or pump.
As you can see there's a bug difference in IAT2 temps from the standard Whipple setup to the PNR trunk mount tank and that the ice made an even bigger difference. The PNR tanks are super high quality, made here in the USA and are sold as the tank by itself or as a kit with the pump, hose and fittings for a complete install.
If you guys have any other questions please feel free to ask. We're always here to help.
PNR Ice Tanks
https://www.lethalperformance.com/pnr-mustang-intercooler-tank-complete-kits-for-install.html
VTR16
Fort Worth
2016 GT 400A PP MT82
Fantastic info!!
Do you guys have the ambient temps during the tests?
What level of tank setup is on the car?
Which pump?
5 or 7 gallon tank?
What size of AN fittings?
LethalPerformance
LethalPerformance
Fl
Fantastic info!!
Which pump?
5 or 7 gallon tank?
I'll go through the logs and reply with the ambient temps as soon as I have a moment. I know for a fact it was over 90degs when I went 8's but will make sure from the actual logs.
We're running the stage 4 setup with the EMP pump. The 7 gallon tank with the 16an feed and 12an return line.
VTR16
Fort Worth
Awesome! Thanks for the update!
olaosunt
Indiana
Was the tune pulling timing on the 9.04 pass with ACT peaking at 130* ?
TX-Ripper
SE Texas
2019 Mustang GT PP1 Whipple Stage 2 / 2018 F150 5.0 Whipple Stage 2
Why is the color code on the chart wrong?
LethalPerformance
LethalPerformance
Fl
Is there any reason this wouldn't work on the "original" (gen2?) 2.9 Whipple on a '15 car?
Not at all. The ice tank setup will work on the 2.9L just the same. Let me know if you have any other questions.
Thanks!
LethalPerformance
LethalPerformance
Fl
I'll ask Lund Jr. and let you know if we pulled any timing. I don't believe it did but I'll verify.
LethalPerformance
LethalPerformance
Fl
LethalPerformance
LethalPerformance
Fl
LethalPerformance
LethalPerformance
Fl
Red is RPM, not black. The color code is wrong in the charts
Good catch. Images have been fixed. Thanks!
No Tank
Tank with water only
Tank with 20lbs of Ice
LethalPerformance
LethalPerformance
Fl
Confirmed with Lund. No timing was pulled. Only if it reaches 150deg will it pull timing.
