How to “restick” the corner of a vinyl stripe?
MCS
MCS
SW Ontario
Michael
2021 GT Premium
m 77 adhesive is what i would use. Tape off the bumper around it, and be delicate with how much you apply. let it tack up for a minute or two before you stick it back down.
I ordered some today from Amazon!
The plan is to...
- Spray some into a bottle cap (clean)
- Use a q-tip to wet the end
- Carefully apply to the bottom of that corner tip
- Wait 60 seconds
- Press down
I'll do this 1 or 2 days before it goes back in for Ceramic Coating maintenance layer and that should cover me off.
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
The plan is to...
- Wait 60 seconds
- Press down
Good luck! Let us know how it goes
  • Like
Reactions: MCS
Dabitz
New Jersey
2019 Mustang GT Premium
So I was washing the car yesterday as it’s time to get it ready for the season. I noticed a very small flap on the edge side on my front bumper. What are other people doing when they run across this? Is there a way to add a little bit more adhesive to lock that down?
It’s the section between the hood and the grille. So the top of the fascia?
For context, I am using the BigWorm kit. They did give me however, I can see what options I have before going that route.
My local shop used quick passes with a torch.
MCS
MCS
SW Ontario
Michael
2021 GT Premium
Ok, it was 7c up here today so I snuck down to the garage. Ensured that the area was clear, sprayed a little into a bottle cap (cleaned out of course), let it sort of "tack-up" and then applied it with a small q-tip then cleaned the area around it.
Will let it "cure" (if this stuff needs to do that) and then check on it in an hour or two.
The car isn't being driven any time soon so it has time.
Eventually, at the start of May, it'll have a maintenance coat of Ceramic Coating applied which should add an additional later.
That damn 3M 77 stuff. Amazon only had the "We don't care if you need a small dab of it we are selling you enough you could stick someone to a ceiling" sized can.
