Makes sense on a car that has no camber, but a camber’d car is going to wear the inside in both cases.Toe is the problem.
\ / wears inside of tire.
/ \ wears outside of tire.
Camber can cause problems but doesn’t eat tires like toe problems.
The S550 Mustang has no factory front camber adjustment, same as many cars with McPherson strut front suspension. The only "adjustment" would be to loosen the strut mount bolts, but that gets you next to nothing.Take it to another shop. No kit is needed to adjust camber. All cars have adjustable front camber. Your car has too much negative camber.
What he said, your toe is out.Excessive front toe is usually the main contributor to uneven/quick wear.
Just in case someone does need to adjust the camber up front.. SPC makes Camber adjustment bolts AND you can get a Camber gauge from them too. I've used their gauge for years on Ford TTB suspension (early 90's explorer) and the Mustang strut front end (2006).The S550 Mustang has no factory front camber adjustment, same as many cars with McPherson strut front suspension. The only "adjustment" would be to loosen the strut mount bolts, but that gets you next to nothing.
