tdstuart
Need some help diagnosing my damaged differential. Wanted to see if any experts in here might know what is wrong since I know next to nothing about differentials.
Car is a 2015 mustang gt, 6r80 with the 3.15 differential. ~125k miles on diff.
Started noticing noise when going from drive to reverse. Progressively got worse, eventually car would make a loud bang when flooring in 1st due to the differential case flexing up and hitting the gas tank. Noticed very worn differential bushings so I replaced them with aftermarket polyurethane bushings. Fixed the differential case flexing but the noise is still there and even more pronounced.
Sounds like a gear-grinding noise. Happens when down-shifting, stopping, starting from a stop, and when going from drive to reverse and reverse to drive. Specifically, when going from drive to reverse and back you can see the suspension loading and the car makes multiple clicking noises coming from the differential.
When I drained and replaced the fluid after installing the bushings there was some metal sludge sitting at the bottom of the case.
Jacking the car up I can make a similar clicking sound by slightly turning the wheel back and forth. It will click but the driveshaft will not move unless I put a little more force and turn further. Happens with both wheels.
The car also makes a lot of clicking noises after parking the car when hot. Definitely not just exhaust cooling down, the differential seems to distinctively make a loud click every few seconds.
Any feedback or opinions are greatly appreciated! Trying to find the most budget-friendly thing to do. Not sure if I can just replace ring/pinion gears or the actual differential gears.
