Heavy clutch
tommyd
northern new jersey
2020 EcoBoost HPP manual
Hi. So I purchased a used 2021 gt manual with 6000 miles on it a year ago. The clutch seemed heavier than normal but unfortunately I didn't make an issue of it at the time. Well it's become more and more difficult to drive the car in traffic . A trans shop believes it is an aftermarket pressure plate that's heavier than oem. So if I want to keep this car I absolutely have to remove the existing p.plate for a lighter one. Besides the oem plate is there another alternative? I just want to enjoy driving a manual again. Any advice is appreciated. By the way,Ford was no help
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Check to see if spring has been removed first(it’s inside right above the clutch pedal).
second go to gym and work out your legs if you can
Third you have the option to get the stock clutch back on if that’s the case, the stock clutch is way to light imo (that’s why I put the steeda clutch spring on mine and it’s perfect now) Or a lighter aftermarket replacement.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Thanks. I have the steeda clutch spring in now
Made no difference
Thats strange. I hope someone here has another idea but I am afraid its probably a heavy aftermarket clutch. The S550 clutches are super light stock, in fact my S197 GT clutch was heavier than my current Mach 1.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
I felt the Steeda clutch pedal spring made the pedal heavier, but better feel.
The OEM clutch pedal spring made the pedal lighter, but more numb.
Yep you are right. It does give it a more linear feel but it gives it some weight which I like. The stock one felt like a feather to me.
CarmeloS
Central Jersey
Carmelo
'21 2dr Bronco Badlands
Definitely watching
I remember the 3v Clutch in the '05-10, it was a leg press. Cyclones and Coyotes are as light as my old Audi and my Bronco, so something was definitely done
stang1087
Aaron
2018 GT Premium
There is a large plug on the driver side of the block you can pop out and see the flywheel. It's pretty much where the starter is located but on the driver side. I believe all clutches for 18+ cars are sold as a kit with a flywheel. You should be able to easily see if the flywheel is billet of cast.
I put in a McLeod RST and the pedal feel is comparable to stock. That's an option if you have a stock clutch that is trashed.
tommyd
northern new jersey
Thanks guys for your imput. I'm waiting for an appointment to discuss my options. But for sure what ever is in there is coming out.
NightmareMoon
2016 Mustang GT PP
Made no difference
The clutch pedal assist spring assists your press on the pedal, it lowers pedal effort.
So the lighter steeda spring causes a heavier pedal. (less assist = heavier feel)
Go back to the stock assist spring if you want a lighter clutch feel.
tommyd
northern new jersey
So a local trans shop (very reputable) said the job to replace the clutch to oem will be about $2200. A Ford dealership said the job will start at around $3000 and could be as high as $5000. Maybe I should sell lol.
CarmeloS
Central Jersey
Carmelo
what mods do you have or planning on getting? There are better aftermarket alternatives
Paul McWhiskey
The Down Side of the Hill
Paul
2017 Mustang GT Premium w/PP
