Stripler
- May 25, 2015
- Northern VA
- 2016 Mustang
Yesterday I left my car with m6g member Grimace's shop in Northern VA to get my GTPP suspension upgraded with:
1. M-FR3A-M8 - Ford track handling pack
2. BMR TCA045 - spherical vertical links
3. BMR CB005 - cradle bushing and lockout kit
4. Steeda subframe alignment kit
5. Steeda rear diff inserts (red)
Installing soon (will try to tackle next week with tools on order):
1. BMR BK055 - rear LCA bushing
2. Ford Performance toe link knuckle bearing
Initial impression: Grimace did an awesome job! There are no squeaks or any odd sounds whatsoever. The most noticeable differences are in steering and braking. The car is extremely composed as a whole, but I immediately think I am in track mode with the steering when I first start the car and then track mode takes the steering to an whole other level. I did middle setting on front sway and firm on rear. I personally like heavy steering and it's much heavier.
The braking has improved substantially with the stiffer suspension. There is no nose dive at all which for a half second makes me feel like the brakes are wet or not engaging even though they definitely are. It is just a psychological reaction because I am so used to the car pitching forward as I brake.
As far as NVH - this is a daily driver and I put almost 20K mi a year on my car presently. There is a bit more road noise from having a stiffer suspension, but nothing that is really that noticeable to me. It sounds like it should - I am hearing things and getting road feedback that I expect with a higher performing suspension and I'd be disappointed if I wasn't hearing/feeling that feedback. As for gear whine with the rear diff inserts - I can only hear it on throttle at parking lot speeds if the radio is off and I listen for it. I have an ARH catback with a good rumble, so I'm sure it drowns out some things, but the gear whine is not consequential for me at all - barely noticeable and I notice a lot. All it takes is the slightest road/wind/tire noise once you are going over 10 mph and I can't hear the gear whine (in my car).
Overall - it feels like a brand new car and a true sports car. I had a 2002 WS6 which weighed about 3350 lbs and a solid rear axle. It didn't handle bumps in the road well, but otherwise handled pretty well. Finally I feel like my Mustang is the sports car I wanted from the start. Great handling and I'm more connected with the car and road. I reminds me of how my lighter, stripped down Trans AM with suspension upgrades was 15 yrs ago, but better.
The GTPP suspension is good and I still would have gotten that package if only for the brakes, but I have no regrets with the upgrades I've made. The RLCA bearing and toe link bearing will finish it off for me. At some point I may upgrade the stock sway bar connectors as they're probably one of the weakest links left, but otherwise I am extremely satisfied.
