When you have 10,000 rpms to play with 5.12s are probably no big deal.Thats too wimpy actually, I used to have an rx8, and MAZDASPEED sells 5.12s!
Stock rev limit?With 3.55's in mine, I'm already to the point I need to shift to 5 to stay in the curve in the 1/4 mile. I've been thinking about going the other way (from 3.55 to 3.33) to keep from shifting to 5th..
I have no idea how you're not just spinning your tires launching that high. Do you have TC ON?I'm still debating the gear change. I spent Friday night at the track and learned a good bit about my car. My best time was 14.0 at 92 mph and a 1.9 60, would have been faster but at the top of the track I missed 4th. Every other run was 95-96mph with little to no spinning. The car needs to be launched hard at high rpms, my best run I left at 4300 rpms. That's what makes me think 3.73 would help by increasing torque in first and second so I can launch at a lower rpm.
Yes stock tire diameterAre you on stock size tires?
6,800 rpm limiter, I short shift and that is past the curve, better then shifting at this point, but still past the power curve. When I make more power, I'll have to shift, or make the curve move to the right on the rpm scale.Stock rev limit?
I think if you go big turbo in the future you will regret changing to 3.31s, but if its going to be a while go for it.Yes stock tire diameter
