- Sep 14, 2020
- Wellington, FL
- Jake
- 2022 F-150 RCSB 5.0
Hey all!
We just got a fresh re-stock of Steeda Autosports here at Lethal Performance!
We have all your Steeda S550 Favorites in stock here at Lethal Performance, including their…
MagneRide Sport Lowering Springs (SDA-555-8242)
- Lowers your 2015+ Mustang 1" on all 4 corners
- Great ride quality, improved aerodynamics, and improved vehicle stance
- Sharper steering response, improved vehicle handling, and stability, noticeable reduction in nosedive
- Fits coupe and convertible
https://www.lethalperformance.com/s...ering-springs-2015-2022-mustang-555-8242.html
OR
2020+ GT500 Dual Rate Ultimate Handling Lowering Springs : https://www.lethalperformance.com/s...-springs-2020-2022-shelby-gt500-555-8244.html
Adjustable Front Camber Plates (SDA-555-8139)
These are the Ideal choice for any lowered street or track Mustang to correct your front camber after lowering.
- Reduce excessive uneven tire wear which can result from lowering your car
- Most adjustment range on the market: adjust camber angle from -0.3 degrees to -2.8 degrees
- Highest quality, stainless steel, Teflon-lined bearings included
- Increased front grip, turn-in response and cornering performance
- No increase in NVH
- Steeda American-made quality, backed by a lifetime warranty
- Compatible with KW Suspension V3 Coilover Kits and Performance Pack shocks
Camber Plates : https://www.lethalperformance.com/steeda-front-camber-plates-2015-mustang-555-8139.html
Billet Aluminum Vertical Links - Polyurethane Bushings (SDA-555-4129)
Polyurethane Bushings Recommended for handling applications (Street, Road Racing, AutoX). Delrin Bushing Recommended Drag Racing & to eliminate wheel hop.
- Reduces wheel hop
- Provides better handling characteristics
- Will not flex under load
- Made in the USA
- Lifetime Warranty
https://www.lethalperformance.com/s...ith-poly-bushings-2015-2018-all-555-4129.html
MT-82 Tri-Ax Race Short Throw Shifter (SDA-555-7317)
- 30% throw reduction, with being 20% lighter than the competition
- Eliminates slop and shifter deflection
- Shift knob sits 1" lower for ideal ‘power shifting’ position
- Top-loaded installation with adjustable springs, in-car assembly
- Retains factory pull-up reverse lockout, OE thread pitch, and back-up camera functionality
Tri-Ax Short Shifter : https://www.lethalperformance.com/s...ow-shifter-2015-2022-mustang-gt-555-7317.html
Full-Length Jacking Rails for Coupe (SDA-555-5212)
- Will work with Steeda’s popular IRS Subframe Support Braces
- Powdercoated for a sleek and durable finish
- Full-length design for greater stability and additional jacking point options
- Includes all necessary mounting hardware
- Provides extra room for jacks and stands
- Lifetime warranty
- Made in the USA using high-grade materials
https://www.lethalperformance.com/steeda-s550-full-length-ultra-lite-jacking-rails-555-5212.html
Of course, we’ve got a ton more Steeda in stock here at Lethal Performance.
Check out ALL Steeda here!
https://www.lethalperformance.com/search/?q=Steeda
If you have any questions, looking for something in particular, or want to get something on order, feel free to reach out to any one of us here at Lethal Performance!
