Spykexx
- Sep 8, 2016
- Quad Cities, IA
- 2019 Mustang GT Prem M6, 2019 Charger Scat Pack Plus
Hell even 3.55's need third gear to hit 60 stock. Tops out around 57-58 :frusty: If I didn't have to shift to third I could easily drop my 5.7 stock 60 time.3.31 are going to kill your launch. I have a base model that HAD 3.31. I dropped in a 3.73 Torsen GT diff and my launches are SOOO much better now. Makes a huge difference as the turbo 4 is finicky to launch with a manual.
By the way, 3.73 is really good for 1/4, you'd trap (assuming your making the power) at around 106~108 in 4th gear with 3.73 at around 6000~6100 RPM, that's right at the end of the best of power band with the FP tune.
If your running a stick, I would HIGHLY recommend getting 3.73 gearing. I still get about 31~32 on the highway cruising at 77~78. I get about 34 cruising at 60~65 with the 3.73.
Although your 0-60 will suck with a 3.73 because you can't hit 60 in 2nd unless you put 28 inch DR's on it.
Best I was able to do with 3.31's with the stock 235 tires which sucked was 5.3. I would have probably shaved off another .1~.2 seconds with good tires that I could launch with. I found 2500 RPM and slightly slipping the clutch to get me to 5.3~5.4 consistently, anything more and I'd smoke the tires.
Haven't tried to time 0-60 yet with 3.73 due to needing to shift to 3rd, but it launches much more easily and consistently with that short first gear. Daily driving is also much easier in my opinion in the city due to easy starts. I can leave it in 6th gear more often as well without dropping below 1500 rpm etc. I think the only consideration for 3.31 in an EB is fuel economy or crazy power like 600HP+. 3.55 should in my opinion have been the standard gearing and 3.73 should have been the PP gearing like the GT.
The MT-82 on the GT is geared slightly higher internally than the MT-82 on the EB and V6, but 5th gear is 1:1 on both variants of the MT-82, so the GT would have about 10mph higher top end due to the extra 500 rpm (150 vs 140). Honestly though, there aren't many tracks that would permit those speeds without 500HP+, so most circuit tracks you see 110~130 at most which is right in the power band of a 3.73 gearing and FP tuned EB power band (5th gear at 6100 RPM is about 130).
