faulty blow off valve?
dfr1990
LI, NY
2015 ECOBOOST BLACK
has anyone had any issues with the factory blow off recently i noticed some compressor surge under high boost i have had other turbo vehicles and i know its not good just want to know if anyone else is having this issues again its only under high boost car has map cold air intake unleashed tune and turbo back exhaust all my previous cars where mechanical bov first time dealing with electronic thanks for any suggestions :cheers:
willmkent
'Twas sure good see'in ya
Michigan
Will
2015 Ecoboost PP
ok, I have been lucky as hell with all my turbo cars and never actually experienced compressor surge. how do you identify that compressor surge has occurred, I am having an issue with my EB under High boost as well and I wonder if this may be a contributor?
dfr1990
dfr1990
LI, NY
2015 ECOBOOST BLACK
i will try and set up my gopro later to record it
willmkent
Michigan
Will
2015 Ecoboost PP
right on. Good luck BTW, I've already had several issues with this car, but hey, its a first year debut, so I guess i should have expected some issues
EnFOURcer
United States
www.turbosmartusa.com
2015 Ecostang, 2015 5.0, 2007 GT500, 2014 Tremor
There is a good chance that its not compressor surge at all and it is simply the sound of the factory BPV venting into the intake.
Aftermarket intakes make it very noticeable because they are "wide open" and you hear everything.
TunaFish15
2017 SRT Challenger owner
Unregistered
6.4L Mustang Eater
Does it sound anything like mine? Kinda does a quick bark/whiplash sound instead of the whoosh sound:
[ame]
dfr1990
dfr1990
LI, NY
2015 ECOBOOST BLACK
Yea ever figured it out?
Sent from my SAMSUNG-SM-G850A using Tapatalk
TunaFish15
Unregistered
6.4L Mustang Eater
Not really. I am using the MAPerformance intake but that's it, no tune. I just avoid getting into boost too fast so it doesn't bark/surge.
EcoBoostin
NorCal
2015 Ecoboost Premium MT
Any update on this issue? Mine pretty much does the same
This with same map intake. From sac I see, nice.
Roidrage
Canada
2.3L Ecoboost Mustang with PP
under high boost and heavy throttle shifting I get it everytime I boost to 20psi. Is this truly compressor surge or just MAP intake should under heavy boost?
Buhbuhj
NY
2015 EB Premium
I recall it being explained that it was just the solenoid in the stock bpv being weak and bouncing under high boost.
Buhbuhj
NY
2015 EB Premium
It doesn't seem to be harmful but if you wanted to fix it you would have to switch to a mechanical bov/bpv.
