engineermike
This is definitely how I would do it.You probably could connect the ECU FDM control wire into this and control it via the ECU.
I'll admit I'm not 100% sure of the following, so take it FWIW.Basically does running 18V in shorter pulses equivocate to the same pump output as running 13V in slightly longer pulses?
I fully admit that I struggle with wrapping my brain around how all of it works (comprehensively). My initial post was more about the end result and the principle involved. If spinning the pumps at a higher voltage would result in the same power consumption (just less amps at higher voltage) to maintain the pump output the controller is commanding.I'll admit I'm not 100% sure of the following, so take it FWIW.
In a brushed DC motor, PWM simulates lower voltages by switching full voltage on and off at some set frequency and modulating the pulsewidth when the voltage is "on" to change the power delivered. The frequency does not determine the speed and just needs to be high enough to simulate a constant reduced voltage.
A brushless DC motor runs near "sync speed", such as an AC motor attempts to run constant speed synchronous to the grid at 60 hz. So rather than modulating the pulsewidth at constant frequency, it modulates the frequency and the motor attempts to match it in speed. (That said, it typically does use PWM to create a sine wave since it only has DC available, but that's another rabbit hole). That said, the motor is always attempting to run sync speed, whatever that may be, with some small amount of slip. More voltage wouldn't increase the controller output frequency, unless of course the controller has the smarts to increase the speed as a function of voltage available. If the controller output speed doesn't increase with voltage, then the only effect more voltage would have is to reduce slip. This slip usually isn't more than about 5%.
I was off on my terminology, not the "controller" but the electronic regulator signal/command. I realize the controller just passes through, I'm talking about the brain.The control signal, from the ECU or regulator as you have setup, is an open at low frequency and a ground at high frequency.
The voltage going to the controller and being modulated to run the pump speed is a seperate circuit. The pump is not getting an alternating current.
Think of the pump controller as a relay or transistor.
I have an HPT Ngauge but again, there's nothing to log. The fuel system is completely independently controlled. The only thing I can observe is fuel pressure and the PCM injector information.What data logging systems do you use?
