Dr. JL
So what did you find out? My Voodoo is making the same noise after warmed up, if shut down for approx. 30 mins and restarted. Rattle eminates from the pass-side front and lasts for approx. 2 secs. Local Ford tech says its an oil leak from a timing chain tensioner so the sound stops once the oil P is returned. My research yields much caution continuing to drive (even after the rattle dissapears) since bits "down stream" are losing much-needed lub.
