vogtaction
I need your guys help, last week I installed the diode dynamics RGWB drls and have the five wires wired into the controller then to power I tapped into the passenger side parking light + and the ground to a bolt under the hood. I want to buy these multiple leds to put into the heat extractors and wire them into the same controller so they all work off the same remote. Do you think this will be a problem, especially since the led only have B G R and the drls have B G R W. Do I just not worry about the one less wire? Will the controller still work with them ok? I dont want to burn any of the drl leds out for SURE. Below is the links of the leds I want to get and the diode dynamics wire diagram.
By the way I dont have the switchback RGBWA ones. just the standard RGBW
http://www.ebay.com/itm/2x-6-LED-Multi-Color-Flexible-Strip-Accent-Lights-5050-SMD-/271458584937?
http://latemodel.cachefly.net/downloads/instructions/DIO-15DRLLED.pdf
