dwaleke
They all would if they could.But in real world aftermarket instances, no one does this.
Agree to disagree.They all would if they could.
Because crank numbers are higher, and therefore more impressive.Why's everything from Roush posted in Crank HP?
Hi there
Two questions for Roush/TVS
1. Does installation of the TVS still require cutting/modification of the block to fit the kit?
2. Is this 740WHP on a stock engine? Any upgrades to oil pump or fuel pump? What is RPM limit set at?
Not good! :(YES you cut and hack to install the TVS. The front cover gets cut for clearance the valley gets cut and you destroy the EVAP lines. So basically if you ever wanted to return stock it will cost you a lot in parts that get destroyed. also you cut the back strut tower brace for clearance. ... worst kit I ever installed
The cuts are actually very easy to make. That was the part of the install that gave me the most anxiety but turned out to be very easy. I used a Dremel Multi-tool with a metal blade. All of the cuts only took me about 10 minutes, and the tool cut so cleanly there was only a metal powder left to clean up. The one EVAP line does need to be cut, but I think could be put back together if needed. I never installed a Whipple kit, so I can't say whether or not the Whipple would be easier to install. I installed my Roush kit in my garage using basic hand tools. The entire install took about 8 hours. The instructions provided by Roush are very well written, and have detailed pictures of every step. I installed a Procharger kit on my 2001 Mustang GT a few years ago, and the Roush kit was a lot easier to install.
I will not be purchasing a whipple kit either based on this clown they have representing the company. Very bad marketing. The dude lost my interest when he was basically talking smack about how they're tuning was so much superior to lunds tuning. I'll be getting a beefcake or vmp stage 3.
Ford Performance went with the 2.9L for there Cobra Jet project, when power is needed, Ford, Dodge and GM come to us. That is a testament to the product. Roush makes a great product but it is simply not a comparable product.Glad I got the roush as well.
Sent from my iPad using Tapatalk
We just did an install on both, Roush took 2.5 hours longer with the same mechanic and the same tools. The grinding was actually 1.5 hours as you need to mask off, grind and clean up. It's a big mess with all the aluminum flying around. To put back to stock, you would have to buy a new timing cover and put it on, looking at 4-6 hours of work plus the parts.The cuts are actually very easy to make. That was the part of the install that gave me the most anxiety but turned out to be very easy. I used a Dremel Multi-tool with a metal blade. All of the cuts only took me about 10 minutes, and the tool cut so cleanly there was only a metal powder left to clean up. The one EVAP line does need to be cut, but I think could be put back together if needed. I never installed a Whipple kit, so I can't say whether or not the Whipple would be easier to install. I installed my Roush kit in my garage using basic hand tools. The entire install took about 8 hours. The instructions provided by Roush are very well written, and have detailed pictures of every step. I installed a Procharger kit on my 2001 Mustang GT a few years ago, and the Roush kit was a lot easier to install.
You do realize the entire belt system is bolted to the timing cover right? Not a big deal?The previous model years timing covers cost about $120 if i recall, not a huge deal, unbolt it and replace with the new one if it came down to it.
